Vista - stereo mix problem
Old 02-16-2009   #1 (permalink)
Vista Home Premium 32bit.
stereo mix problem
I have a problem were I cant seem to get stereo mix I have tried everything but nothing works any help? here is the picture of my recording devices
Old 02-16-2009   #2 (permalink)
Re: stereo mix problem
any help?
Old 02-16-2009   #3 (permalink)
Vista Ultimate x64 SP1
Vista does not have a stereo mix (as far as I know). It uses a different sound processing structure to XP.
Old 02-16-2009   #4 (permalink)
isn't there some sort of driver i can install?
Old 02-16-2009   #5 (permalink)
Not that I know of... Just looking a bit harder at the image you posted, you could set the 'Line In' to default as that should record in stereo. You will the need to plug what you want to record off into the 'Line In' port/
Beyond that I am not sure what you could do.
Old 02-17-2009   #6 (permalink)
Vista Home Premium 32-bit & Vista Ultimate 64-bit both Service Pack 2 W7 Pro RTM 7600 32 & 64
Hi computerdude123,
Have a look at this:Stereo Mix / SigmaTel Drivers Installing Problem
Old 02-17-2009   #7 (permalink)
Ive tried that but it doesn't work either.
Old 02-17-2009   #8 (permalink)
I'm looking to see if i can find a driver that i can install to my computer to give me stereo mix
Old 02-19-2009   #9 (permalink)
can someone help please here is the model
Stereo Mix / SigmaTel Drivers Installing Problem Sound & Audio
stereo mix Vista performance & maintenance
Stereo Mix and Sigmatel Audio and driver problem! Sound & Audio
Car Stereo Chillout Room
A2DP Bluetooth Stereo Vista Problem Vista General
