Vista - Sound Help
Old 02-22-2009   #1 (permalink)
Windows Vista Home Premiumm 32bit
Sound Help
I have a problem (obviously). My laptop will not play sound. When I hover my cursor over the sound icon in the lower-left corner of the screen, a message pops up stating that 'No Audio Output Device is installed'. Does anyone know how to fix this?
Old 02-22-2009   #2 (permalink)
Vista Ultimate 64
Re: Sound Help
Quote  Quote: Originally Posted by Carakki View Post
Go to control panel, device manager, sound,video and game controllers, double click, is there a sound driver. I would assume that there is onboard sound even though you have not listed any of your laptops specs.
If there is a device, try downloading the latest driver for it from the device manufacturer and you should now have sound.
Good Luck !
Old 02-23-2009   #3 (permalink)
Re: Sound Help
Quote  Quote: Originally Posted by Litewave View Post
Good Luck !
Thanks for the assist. I found the place you're talking about, but when I tried to update the driver, it said I had the latest version. Is there anything else I might try? I'm sorry if I seem to lack initiative, but I have no experience with things like this.
Old 02-23-2009   #4 (permalink)
Vista Ultimate 64
Re: Sound Help
Good Luck !
What type of equipment are you using ? ie.. laptop brand, model # and what sound device is in it?
Old 02-23-2009   #5 (permalink)
Re: Sound Help
Good Luck !
Um...well, my laptop's from Toshiba. When I look at the driver, it says that it's a Realtek High Definition Audio. Where would I find the model #?
Old 02-24-2009   #6 (permalink)
Vista Home Premium x64
Re: Sound Help
distorted sound in vista/createiv x-fi titanium sound card Sound & Audio
Solved No sound when playing music or video, but internet sound works fine Sound & Audio
Setting per Application Sound Output, or Per Sound Type Outputs... Vista General
My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! Vista General
Vista x64 RC2 - Sound Card/Amplifier - DTS Test Sound (Audigy 2 ZS SPDIF) Vista General
