Big Sound problem (need help soon please)
kotletPL
Big Sound problem (need help soon please) SOLVED
k heres the deal....
I've had my new computer built for 3 days now. Ever since i have had it i have had no sound.
I've searched endless forums looking for ppl who have had similar problems trying to resolve mine.
But no luck so i finally gave up and decided to write about it.
K so the problem is the error that hunts my new pc "No Audio Output Device is Installed"
-my audio is realtek hd audio-
yes, i have tryed installing the driver from my motherboard disc..and yes i have trying getting updated drivers...this does not help...
the reason..
when i go to device manager .... i have no Sound, video, and game controllers tab !
WTF? .so that is what i need to fix first and then i thinkk i can fix sound by installing drivers.
Comp Specs=(also in my dxdiag attachment)
Operating System: Windows Vista™ Home Premium (6.0, Build 6000) (6000.vista_gdr.080917-1612)
Language: English (Regional Setting: English)
System Manufacturer: XFX78I
System Model: XFX nForce 780i 3-Way SLI
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: Intel® Core™2 Quad CPU Q6700 @ 2.66GHz (4 CPUs), ~2.7GHz
Memory: 4094MB RAM
Card name: NVIDIA GeForce 9800 GTX/9800 GTX+
Sound =(
Sound Devices
Description:
Default Sound Playback: No
Default Voice Playback: No
Hardware ID:
Manufacturer ID:
Product ID:
Type:
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
HW Accel Level: Emulation Only
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX™ 2.0 Listen/Src: No, No
I3DL2™ Listen/Src: No, No
Sensaura™ ZoomFX™: No
Please Help mates
  • DxDiag.txt
the reason..
Memory: 4094MB RAM
Sound =(
Sound Devices
Description:
Hardware ID:
Manufacturer ID:
Product ID:
Type:
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
Cap Flags: 0x0
HW Memory: 0
Please Help mates
do you have your onboard audio enabled in the bios?
should be under integrated peripherals.
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Samsung 7200rpm 250Gb SATA,
    Samsung 7200rpm 750Gb SATA,
    WD 7200rpm 1TB SCSI SATA.
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
ok, have you scanned for hardware changes in the devices list, the sound, video and game controllers options wont come up unless there are any in your system.
    16Mb Sky bb
With the HD audio drivers...you have to install it twice...the first time removes the current driver and the second time installs the driver.
If you forget the number of times you installed you may accidently just have no drivers installed
hehe, wait a sec, i got the solution on a plate for you, type in the start menu search bar, "services.msc" without the speechmarks, and hit enter, this will bring up a UAC prompt for the microsoft management console, continue, and near the bottom of the list, can you tell me what it says next to windows audio?
make sure the service is saying started, if it says its stopped, then on the left, click on start this service as illustrated below, and set to automatic by right clicking windows audio and set to automatic.
also make sure the windows audio endpoint builder is the same as windows audio.
Restart your system and enjoy glorious High definition audio
    16Mb Sky bb
well, ive looked at a few similar problems to this and the solution appears to be to uninstall your device completely from the device manager, restart and let windows install it, good luck.
    16Mb Sky bb
yeah i've givin up and installed my xp home edition back after nothing worked
thx for giving ur time to try and solve the problem=) U can mark this topic as fixed . I gave rep. to all those who tryed helping thx again.
no problem, sorry we couldnt solve the issue, but if you plan on giving vista another try, dont hesitate to visit again if you have any problems, and the topic being fixed is a prefix only you can check
    16Mb Sky bb
