| vista home basic 32bit | DSP Group TrueSpeech™ Audio CODEC I keep trying to play a wav file and keep getting "DSP Group TrueSpeech™ Audio CODEC "needed number22.This is for medcal transcription wav fie. I searched and found a step by step fix posted by coolchris. However I can't install the new codec as I can't find the proper .inf file in folder system32. |
| Vista Home Premium x64 | Re: DSP Group TrueSpeech™ Audio CODEC I keep trying to play a wav file and keep getting "DSP Group TrueSpeech™ Audio CODEC "needed number22.This is for medcal transcription wav fie. I searched and found a step by step fix posted by coolchris. However I can't install the new codec as I can't find the proper .inf file in folder system32. |
| vista home basic 32bit | Re: DSP Group TrueSpeech™ Audio CODEC thanx for responding I downloaded a full vista codec pack from majorgeeks.com and it worked!!!! |
| Vista Home Premium x64 | Re: DSP Group TrueSpeech™ Audio CODEC yep, usually the case, glad you got it fixed |
| DSP Group TrueSpeech™ Audio CODEC | Sound & Audio | |||
| DSP Group TrueSpeech Audio Codec | Sound & Audio | |||
| truespeech codec | Vista General | |||
| DSP Group TrueSpeech codec | Vista General | |||
| dsp truespeech codec | Vista General | |||
