Vista - problem with mic
Old 03-10-2009   #1 (permalink)
Vista Home Basic 32bit
problem with mic
ok i have i notebook pc and it has built in mic. what bothers me is that when i use skype (i mean talking) mic keeps muting it self and if i want to speak i have to push back slider in mic properties manualy everytime i start to speak. anyone can help with this problem? thanks in advandce!
the problem with ndis.sys Blue Screen of Death problem solved? Vista General
Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 Vista mail
Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! Vista General
Generic McAfee Problem Message in Vista Problem Reports Vista performance & maintenance
Vista Upgrade Problem - Windows Explorer Loop problem Vista installation & setup
