Realtech HD Audio Manager not working with front jacks
Megz
It shows my front jacks. But when I plug in my headset nothing pops up, and I can't manually click the jack. Having to pull out my entire computer every time I want to plug in my headset it really really annoying, which is the whole reason I got jacks on the front of my computer...now they don't work?
    Intel(R) Core(TM)2 Quad CPU
    I know it's made by MSI that's about it
    4gigs RAM
    NVIDIA GeForce 9800 GT
    *shrugs* RealTek I'd guess
    LCD I'm fairly certain, one corner says HDMonitor and the other says emachines.
    don't think i ever knew
    not even sure what this is
    it's pretty and i can see through one side...it glows!
    I see 2 fans.
    Not sure, it's a Dell
    Also a Dell
    Cable
    I really don't know where to find any of this information. We bought the computer online from a website that builds gaming computers. I know it's pretty and it lets me play WoW at a normal speed. If I wanna sound like I know something about computers I throw out the words "4gig Quad Core!"
Hi Megz,
Welcome to the Forum,
You need to check that the front speakers are connected to the motherboard. There are up two connectors one is for HD (mine is yellow) and the other for AC97. You now need to Enter the Bios and check that Front Panel Audio is selected to the same HD or AC97
I hope this helps
Pooch
    Self build
    Asus M3A32-MVP Deluxe
    8 gig Samsung PC800 RAM
    NVidia 9600gt
    AD1988b
    1680 : 1050 1280 : 1024
    Drive #1 - SAMSUNG HD252HJ (250 GB)
    Drive #2 - Hitachi HDT721010SLA360 (1000 GB)
    Drive #3 - SAMSUNG HD250HJ (250 GB)
    Drive #4 - SAMSUNG HD103UJ (1000 GB) External eSATA
    Enermax Chakra
    Standard
    Easy Line Laser Mouse
    I have also used Fedora, Suse, Ubuntu Linux
    And all other Windows from 95 to date except ME
EDIT: I did check (although I wasn't really sure what I was looking for) after I posted (and searched the net some more) and it seemed to me that the lines were connected to the motherboard.
I searched and searched and finally figured this out.
1. Go to Control Panel and set it to Classic View.
2. Click on Sound.
3. Go to the Playback or Recording tab (depending on if you're having trouble with mic or speakers)
4. Click on the Speakers/Microphone icon.
5. Go to the Levels tab.
6. Crank up the volume levels.
7. Go to Realtech HD Audio Manager
8. Click the little folder on the side (Connector Settings)
9. Check the box that says 'Disable Front Jack Detection.
Not sure what that did but it's working now. HOORAY.
    4gigs RAM
    I see 2 fans.
    Also a Dell
    Cable
Ok maybe it's not totally fixed.
Now I can't make my speakers mute while my headset is plugged in. Easy enough to live with, I just turn my speakers off when I'm using the headphones.
But if anyone knows how to fix that it would be nice. :)
    4gigs RAM
    I see 2 fans.
    Also a Dell
    Cable
is assume you've setup (see screenshot) properly?
    amd phenom 9950 BE
    M2A-VM HDMI
    8 gb
    Geforce 8600 GTS
    dual 19" HD monitors
    2 x wd 500 sata
    1 x Seagate 500 sata
    1 x Seagate 1000 sata
    1 wd 500 ide
    1 raptor 80 gb
    1 usb maxtor 160 gb
    standard
    wireless MS
    wirelss MS laser 6000
    18 mb according to my ISP :)
