| Business 32Bit | SoundMax problems hi ... i just have installed Vista x64. I had vista x32 before but now i've got Problems with my SoundMax-Software. The Driver from the Asus homepage work very well but not the SoundMax-Software. I cannot install it right ... in the Systemcontrol there is no entry and the Trayicon is not where it should be. Its not hided or something else ... i just cannot use it. The 32bit version of the Soundmax works but it is 32bit. So my question ... is it neccessary to have the SoundMax as x64 or is there no dfference? greetz |
| Vista Ultimatex64 Windows 7 build 7100 | Re: SoundMax problems hi ... i just have installed Vista x64. I had vista x32 before but now i've got Problems with my SoundMax-Software. The Driver from the Asus homepage work very well but not the SoundMax-Software. I cannot install it right ... in the Systemcontrol there is no entry and the Trayicon is not where it should be. Its not hided or something else ... i just cannot use it. The 32bit version of the Soundmax works but it is 32bit. So my question ... is it neccessary to have the SoundMax as x64 or is there no dfference? greetz Welcome to the forum, If the 32bit software works for you then I see no reason to change it. To answer your question, no, there is no noticeable difference ![]() Pooch |
| Vista Home Premium 32bit OS / Sp2 | Re: SoundMax problems Vista 64 bit is a bit faster one .... on doubt about that....But unfortunately ....... you will run into alot of problems to find softwares that work with it. I really DON'T see the eason why you switched to 64...? "If you still have alot of softwares that written for 32 bit...then switch it back.." |
| Soundmax | Sound & Audio | |||
| soundmax | Vista music pictures video | |||
| Soundmax Help | Vista hardware & devices | |||
| SoundMAX Try This | Vista hardware & devices | |||
| RC1 and SoundMax -- funky audio problems | Vista music pictures video | |||
