Vista - ALC272 possible for 4 speaker (quadrophone)?
Old 03-16-2009   #1 (permalink)
Vista Home Premium 64bit
My Laptop (Toshiba A355D-S6930; Vista HP 64bit) using ALC272 (6.0.1.5689) Realtek soundcard and only have a mic and a headphone jack.
Is there anyway to change the mic input for stereo-rear speaker output?
I tried all way to get it, but none.. nothing...
(windows sound in CP, etc.. etc... still show stereo output only...)
Thx in adv... Thankiess...
~My Laptop detailed Specification~
Old 03-17-2009   #2 (permalink)
Vista Home Premium x64
Re: ALC272 possible for 4 speaker (quadrophone)?
Quote  Quote: Originally Posted by YamadaKaito View Post
you need to find out if your mic records in stereo, otherwise you will only get 3 of the 4 channels, plug a set of headphones into the mic and use recording software to find out if its stereo or not, (before you are slightly confused, headphones are effectively microphones) speak into one clearly and speak into the other, playback and if you hear both channels, then all you have to do is open up realtek audio manager, double click on mic (pink) and set it to rear out.
yours will only have panel on it, not front and rear, so ive arrowed both just for principal
Old 03-18-2009   #3 (permalink)
Um.. Thx for Reply... But this after i plug the mic or lineout jack...
It not showing the rear output... Is this the driver version problem or something else?
Big Thx...
EDIT: LOL just found in the spec page that the "Microphone jack (mono)"...
Now, is there any way to get 4 // 5.1 // more via usb?
THX...
Last edited by YamadaKaito; 03-18-2009 at 06:50 PM.. Reason: The Mic jack is Mono (T____T);
Old 03-18-2009   #4 (permalink)
of course, you can get full 5.1 via USB, you need to look around at your local retailer, im not sure about indonesian stores to buy computer components, but heres an idea of what to look for 70SB109000002 - Creative SoundBlaster X-Fi Surround 5.1 - Scan.co.uk
Old 03-18-2009   #5 (permalink)
Thankies... I think that's all... lol
Front Left speaker not working correctly in 5.1 speaker configuration Sound & Audio
Speaker Help Vista hardware & devices
speaker hum Vista performance & maintenance
5.1 speaker Vista hardware & devices
Speaker Help Vista music pictures video
