| Vista Home Premium | Sound Mix Help? ![]() this is what my recording devices thing looks like, I want to be able to record sound on it so i need to know where to get the sound mix thing anyone know what to do? (sorry it's all streched up i messed up) |
| Vista business x64 | Re: Sound Mix Help? Do you have a microphone plugged into one of the MIC jacks or the Line-in jack? I've had the same problem as you before, and even though it showed them as 'not plugged in' you could fix it by right clicking all of them and selecting 'disable'. After you've disabled all of them enalbe the one that the microphone is plugged into and it should show up as working. I hope this helps! |
| distorted sound in vista/createiv x-fi titanium sound card | Sound & Audio | |||
No sound when playing music or video, but internet sound works fine | Sound & Audio | |||
| Setting per Application Sound Output, or Per Sound Type Outputs... | Vista General | |||
| My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! | Vista General | |||
| Vista x64 RC2 - Sound Card/Amplifier - DTS Test Sound (Audigy 2 ZS SPDIF) | Vista General | |||
