Vista - "no audio device is installed"
Old 04-19-2009   #1 (permalink)
Windows vista home premium
So I come to find that my found that the sound no longer works
in my tray I get a sound icon with an X on it.
When I try opening it it gave me that message.
the only thing I have done recently is using the Hp update
I canceled one of the updates, which was for the nvidia graphics driver
could that have caused the problem? how do I fix it?
the only other thing I've done was going into regional settings and adding Japanese.
Help Needed: "No audio output device is installed" Sound & Audio
Dell and "no audio output device installed" after Vista upgrade Vista hardware & devices
"No Audio Output Device is installed"? Vista hardware & devices
"No Audio Output Device is installed" Vista General
"No audio output device is installed" upon wake-up... Vista hardware & devices
