| dont know | no sound yesterday I had sound on my dell Inspiron. Today I have no sound and the small icon on the tool bar has disappeared. A look at sound on the control panel leaves me baffled. help please Ian |
| Vista Home Premium 64bit | Re: no sound What does the baffling bit look like? To help us help you we will need much more information. |
| Vista 32bit SP1 | Re: no sound can you please be a bit more descriptive about the issue. That what happens when you check the sound in control panel. |
| dont know | Re: no sound I see these two options: Speakers/Headphones Sigmatel high definition audio CODEC working. |
| dont know | Re: no sound I see these two options: Speakers/Headphones Sigmatel high definition audio CODEC working. There is a small green circle with a tick inside it. Digitil Output Device (SPDIF Out) Sigmatel high definition audio CODEC working. There is no small green circle with tick If I highlight the second one and click set default button the small green circle moves to the second option. I can move it back to the first the same way. If I click on the properties button it takes me to setting levels, custom, enhancements etc. there are no external speakers, only those in the laptop. I can change the level on speakers but it makes no difference to the sound. I cna also change it on PC speaker but only from zero Db at top to a negative number. nothing I do makes any difference to the sound output. Do you need any more info? |
| | #6 (permalink) |
| x64 | Re: no sound well, check if the speaker stick the PC or not through control panel. and the sound volume is in speaker mode yet? if its still that, need to find technical support from customer service |
| | #7 (permalink) |
| Vista Ultimatex64 Windows 7 build 7100 | Re: no sound I see these two options: Speakers/Headphones Sigmatel high definition audio CODEC working. There is a small green circle with a tick inside it. Digitil Output Device (SPDIF Out) Sigmatel high definition audio CODEC working. There is no small green circle with tick If I highlight the second one and click set default button the small green circle moves to the second option. I can move it back to the first the same way. If I click on the properties button it takes me to setting levels, custom, enhancements etc. there are no external speakers, only those in the laptop. I can change the level on speakers but it makes no difference to the sound. I cna also change it on PC speaker but only from zero Db at top to a negative number. nothing I do makes any difference to the sound output. Do you need any more info? Speakers is the right device, it should be set to default. When Speakers is highlighted you should be able to configure your setup using the configure button. You could try right clicking on the Digital device and select Disable. If this doesnt get your sound back go to Device Manager double click on Sound, video and game controllers, right click on the Sigmatel entry click on properties, click on the Driver details tab and click on Roll Back Driver. I hope this helps Pooch |
| distorted sound in vista/createiv x-fi titanium sound card | Sound & Audio | |||
No sound when playing music or video, but internet sound works fine | Sound & Audio | |||
| Setting per Application Sound Output, or Per Sound Type Outputs... | Vista General | |||
| My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! | Vista General | |||
| Vista x64 RC2 - Sound Card/Amplifier - DTS Test Sound (Audigy 2 ZS SPDIF) | Vista General | |||
