Vista - No sound?
Old 05-02-2009   #1 (permalink)
Home Premium 32bit
No sound?
I have a Toshiba satellite L300 and its running vista.
My speakers work perfectly but when i plug headphones in,
the sound continues play on the speakers and NO sound us heard through the headphones. Can anybody please help me out here?
A small problem, but its overly bugging me..
My computer is:
a Toshiba L300 Satellite
Model: PSLB8A-04S004 ( if that helps )
Intel Pentium Dual-Core.
i think its a Home Premium 32bit, im not overly sure..
any help would be overly appreciated
Thanks!
Old 05-02-2009   #2 (permalink)
Vista Ultimate x64 sp2, Solaris x64
Re: No sound?
Hello Bailee,
Welcome to the Forum.
Sounds like you didn't push the jack all the way into the socket, or the socket is broken. If your machine is brand new there is possibility the socket has tight fit. Try to plug the jack few times so the connectors inside will settle down.
Hopefully it will help...
Old 05-02-2009   #3 (permalink)
Home Premium 32bit
Re: No sound?
Thank you for your reply Martee.
I have indeed tried pushing it in all the way, and it is very reluctent to go in. and when i get the plug into the socket and try to pull it out, it merely takes alot of effort..
Is it a possiblity that water has gotten in there and corrupted the output?
And im only a teenage girl, and i don't really want to mention this to dad haha.
He will shoot me, but i noticed there were alot of probelms vista were having with audio. afew weeks ago i had a probelm the exact opposite to this, my headphones wouldwork, but my speakers wouldnt.
i was browsing through the internet trying to have a DIY porblem fix and i got it. so i thought this would be an easy fix.. guessing its not?
Old 05-03-2009   #4 (permalink)
Re: No sound?
Hello Bailee,
I'm really sorry, I've got no idea how to help you in this. The headphones should work when you plug them in. The speakers should be mute at the same time. My only suggestion is to send your lappy to repair.
Your dad will understand this, I'm sure. It's not your fault, right.
Cheers...
Old 05-03-2009   #5 (permalink)
Vista Ultimate x64 SP1
Re: No sound?
Sounds to me like the socket's broken. Definitely some wiring screw up back in there... when the plug's pushed in it's making the 'switch' for the speakers.
Old 05-03-2009   #6 (permalink)
Home Premium 32bit
Re: No sound?
Thank you both for your replies.
i was really hoping not to have it sent away, but hey. i tried..
i think i did spill water on it an one point, but i was very sure that it got nowhere near the computer.
Thank you for your help, and i shall try to have it sent off.
Old 05-17-2009   #7 (permalink)
vista home premium 32bit
Re: No sound?
i am having the same issue on a gateway desktop and when i go threw the settings and hit the test button they work and when i unplug the speakers in the back and then plug the headphones in they also work fine
distorted sound in vista/createiv x-fi titanium sound card Sound & Audio
Solved No sound when playing music or video, but internet sound works fine Sound & Audio
Setting per Application Sound Output, or Per Sound Type Outputs... Vista General
My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! Vista General
Vista x64 RC2 - Sound Card/Amplifier - DTS Test Sound (Audigy 2 ZS SPDIF) Vista General
