Vista - No sound
Old 05-06-2009   #1 (permalink)
Vista Ultimate x64
No sound
This worked for me before but I messed it up.
I used to be able to record the sound coming from my computer and play it to my microphone right away as it goes.
Meaning when I record something, it would record whatever is playing on the computer.
But I forgot how to make that setting.
Any tips?
I really need this fixed
thanks
Old 05-06-2009   #2 (permalink)
Windows 7 Ultimate
re: No sound
You just need to change the default audio device go into control panel>sound>recording and right click on the Stereo mix and set to default device if you want to record sound from your screen or select microphone if you want to record voice
Old 05-09-2009   #3 (permalink)
Vista Ultimate x64
re: No sound
wow you just fixed a week of frustration.
i checked it before but it din't seem too work.
I love you man. keeping this thread in case the problem pops up and i forgot.
Old 05-09-2009   #4 (permalink)
Vista Ultimate x64
re: No sound
but i have one more problem.
The recording volume is too low.
even though it looks very high in the vertical green activity box. it isint loud =/
Old 05-09-2009   #5 (permalink)
Windows 7 Ultimate
re: No sound
I'm not really to sure about that one..
Mine is quite too.
Does turning up the speakers to full make a difference??
Old 05-09-2009   #6 (permalink)
Vista Ultimate x64
re: No sound
already did. still having problems.
I have really good bass, but i turned it off.
still no. bleh.
Old 05-09-2009   #7 (permalink)
Windows 7 Ultimate
re: No sound
What program are you using to record??
could you possibly give me an idea on what your trying to do.
Old 05-09-2009   #8 (permalink)
Vista Ultimate x64
re: No sound
im not recording anything,
im just using it as my microphone to play something
or just using my sound recorder on the computer.
it isint playing loud at all. =/
Old 05-18-2009   #9 (permalink)
Vista Ultimate x64
Re: No sound
Help!?!?!
Old 05-19-2009   #10 (permalink)
Windows 7 Ultimate
Re: No sound
I'm Really not sure how to fix it. Why do you need to listen to whats on your computer using the microphone rather than just using the speakers?
distorted sound in vista/createiv x-fi titanium sound card Sound & Audio
Solved No sound when playing music or video, but internet sound works fine Sound & Audio
Setting per Application Sound Output, or Per Sound Type Outputs... Vista General
My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! Vista General
Vista x64 RC2 - Sound Card/Amplifier - DTS Test Sound (Audigy 2 ZS SPDIF) Vista General
