| Newbie | Microphone is not working I search the boards but no one really answer this question. I plug in my microphone a couple of times always getting the pop up and then I selected don't ask me again thinking windows would remember this and I can keep using it. Well when I was recording something in a program I notice it wasn't working at all. I double check the mircophone settings and everything is correct. Is there some way I can get that pop up to show again.......? |
| Member | Re: Microphone is not working Possibly update the microphone driver or stick the microphone jack into another jack you may have on your computer or if it a USB microphone then stick it in another slot? |
| PC Geek | Re: Microphone is not working do you know what sound card you have? if it a realtek, simply double click on the orange speaker icon in the corner and double click your jack for the microphone, and select always ask. |
| microphone isn't working | Vista hardware & devices | |||
| Microphone not working | Vista hardware & devices | |||
| microphone not working | Vista General | |||
| Microphone Not working | Vista music pictures video | |||
| Can't get my microphone working | Sound & Audio | |||
