Vista Tutorial - "no audio output device installed"
Old 06-10-2009   #1 (permalink)
Newbie
Windows vista home premium
Hiya, so my problem is that i have no sound, haven't had for a while now.
When i hover over the speaker icon it says "no audio output device installed".
I've tried going to device manager and beside where it says "Realtek AC'97 Audio" is a yellow triangle with an exclamation mark inside. I have tried clicking update driver software and scan for hardware changes.
I have been googling this problem for ages to try and find a solution but anything i can find doesn't work. If anybody could give me any suggestions on what might be wrong and how to fix it i'd really appreciate it.
I don't know much about the computer, it was given to me and i'm not much of a computer wiz. But if you need to know anything i will try to answer.
Thanks.
Old 06-11-2009   #2 (permalink)
CCNA
Windows 7 7600.16385 64bit
Re: "no audio output device installed"
Help Needed: "No audio output device is installed" Sound & Audio
Dell and "no audio output device installed" after Vista upgrade Vista hardware & devices
"No Audio Output Device is installed" Vista hardware & devices
No Audio Output Device Installed "Please Help!!!" Vista hardware & devices
"No audio output device is installed" upon wake-up... Vista hardware & devices
