| | #11 (permalink) |
| Vista Ultimate X64, Windows 7 X64, XP Pro X64, Vista Home Premium X86 | Re: detecting speakers still no sound when you did it did uninstall the driver reboot and than reinstall the driver. |
| | #12 (permalink) |
| vista 64 bit | Re: detecting speakers still no sound uninstalled and reinstalled in safe mode |
| | #13 (permalink) |
| Vista Ultimate X64, Windows 7 X64, XP Pro X64, Vista Home Premium X86 | Re: detecting speakers still no sound try un-installing in normal rebooting into normal and than re-installing. running out of ideas. also do you have any extra speakers to try? if so plug those in and see if you get any sound. |
| | #14 (permalink) |
| vista premium 32bit | Re: detecting speakers still no sound Well I have the same fault as you, just can't see where the problem is so if you find a cure please let me know. Alfie |
| | #15 (permalink) |
| Vista Ultimate X64, Windows 7 X64, XP Pro X64, Vista Home Premium X86 | Re: detecting speakers still no sound i am thinking the sound card is bad. do you have an extra one to try with the speakers? |
| | #16 (permalink) |
| vista premium 32bit | Re: detecting speakers still no sound No but I had this problem a year ago and I cured it without any hardware change but never wrote down how!! |
| | #17 (permalink) |
| Vista Ultimate X64, Windows 7 X64, XP Pro X64, Vista Home Premium X86 | Re: detecting speakers still no sound have you tried to update your drivers? have you tried to uninstall them and than reinstall them? |
| | #18 (permalink) |
| vista premium 32bit | Re: detecting speakers still no sound YES Twice.Going to look at Problems with sound and audio or no sound |
| | #19 (permalink) |
| Vista Home Premium 32bit | Re: detecting speakers still no sound You don't mention it, but did you check the options under the master volume popup you get when you click on the speaker in the systray to make sure mute isn't on ? |
| | #20 (permalink) |
| Vista Ultimate X64, Windows 7 X64, XP Pro X64, Vista Home Premium X86 | Re: detecting speakers still no sound |
| Usb speakers no sound comes out | Sound & Audio | |||
| Speakers sound to "0", but there is still sounds from speakers | Vista music pictures video | |||
| Vista 64-bit not detecting sound stuff? | Vista hardware & devices | |||
| Low sound from speakers and no windows sound on new vista | Vista hardware & devices | |||
| Laptop Sound card + Vista - NO SPEAKERS!! + NO SOUND | Vista hardware & devices | |||
