| | #11 (permalink) |
| Windows 7 RTM 64-bit | Re: Desperatley Seeking Sound Did you try the drivers listed here? |
| | #12 (permalink) |
| Vista Home Premium 32bit | Re: Desperatley Seeking Sound come again.. what is a snip? |
| | #13 (permalink) |
| Vista Home Premium 32bit | Re: Desperatley Seeking Sound the intel site doesnt have downloadable sound driver for my os system |
| | #14 (permalink) |
| Vista Ultimate 32bit SP2 | Re: Desperatley Seeking Sound It is explained in this tutorial. How to upload the picture is decribed in the FAQ section of this forum. |
| | #15 (permalink) |
| Vista Home Premium 32bit | Re: Desperatley Seeking Sound |
| | #16 (permalink) |
| Vista Ultimate 32bit SP2 | Re: Desperatley Seeking Sound Did you fix it? I think that either the audio card or its driver is damaged. Uninstall it and reboot. You have probably tested this already. Next is uninstall, run Driver Sweeper and re-install a new driver from Realtek homepage. Next is remove sound card, uninstall, run Driver Sweeper and reboot, shut down and then put card back and start again. |
| Seeking a utility | Vista General | |||
| Seeking software that can ............. | Vista General | |||
| Seeking a website | Vista General | |||
| Seeking Pointers on UAC | Vista security | |||
| Seeking utility | Vista General | |||
