Vista - Headset problems
Old 07-09-2009   #1 (permalink)
Vista Home Premium x64
Headset problems
So I have a Razer Carcharias gaming headset. I love it to bits. It has always worked properly and very well.
Now today for some reason the mic on it has decided to stop working. I've checked my sound levels and my boost option, and they are all turned all the way up.
So my question to you is, what should I do next to get this working again? I run my own ventrilo server, so its kind of dumb to do that if I can't even talk on it lol.
Thanks for your help.
-Xen00b
Old 07-29-2009   #2 (permalink)
Re: Headset problems
I figured I should give this a bump...its been 2 weeks now..
Anyone got any info that could help me out?
Old 07-29-2009   #3 (permalink)
Vista Home Premium 32bit
Just from a very basic approach.
If you can get another mike that is known to work,plug it in.
If you still get no sound out the problem is in the computer.
If you do get sound,start checking the headset for
loose connections,broken wires,etc.
Old 07-29-2009   #4 (permalink)
There is my problem.
I don't have another headset.
Old 07-29-2009   #5 (permalink)
Friends/neighbors/relatives?
Old 07-29-2009   #6 (permalink)
Quote  Quote: Originally Posted by Xen00b View Post
you can use an old set of headphones or earphones as a microphone, its essentially a reversed microphone anyways, just plug them in and speak through the left earpiece, see if windows picks it up.
Old 07-29-2009   #7 (permalink)
Vista Ultimate 32
Check your Microsoft sound input options
Control panel > Sound - Recording - Set your microphone to default, Right click on it, advanced - advanced - Untick both the Exclusive mode text boxes.
I had a similiar problem, turned out it was my VIA HD audio control panel >.<.
Mic Problems with Vistax64 (SB Audigy2Z & Headset) Sound & Audio
USB headset problems Sound & Audio
Headset problems (help please) Sound & Audio
How to use front Pink Headset, USB Headset, and Rear Speker outputs atthe same time? Sound & Audio
Logitech Headset Problems Vista hardware & devices
