| Vista x64 Ultimate, SP2 | DVD Burner I did a search, but my results didn't quite help me. Can anyone suggest a DVD Ripper (preferably free ) to copy DVDs to my HD and then be able to copy them onto a recordable DVD? I hope to find one that does not take an exhorbitant amount of time.I REALLY appreciate any suggestions. Thanks, Beau |
| Vista Ultimate x64 sp2, Solaris x64 | Re: DVD Burner Hi Beau, You would check the DVDFab-Platinum and/or the InfraRecorder. Here's another one the DVD Cloner .Hope it helps. Cheers... Last edited by Martee; 07-19-2009 at 12:18 PM.. Reason: adding link |
| Vista x64 Ultimate, SP2 | Re: DVD Burner Thanks Martee. I'll ck them out. |
| Vista Ultimate x64 sp2, Solaris x64 | Re: DVD Burner You are welcome Beau, any time. Thanks, Martee |
| No burner is currently available or you don't have rights to access the burner. | Vista hardware & devices | |||
| burner | Vista hardware & devices | |||
| Bad dvd burner? | Vista installation & setup | |||
| Built-in CD Burner or 3rd party Burner? | Vista General | |||
| DVD Burner | Vista General | |||
