Vista - Speakers not working
Old 08-21-2009   #1 (permalink)
Vista Home Premium 32bit
I have dell Inspiron 1420 32bit vista home premium Operating System comptuer.
Till today morning my internal speakers worked properly but they suddenly stopped working. I don't know what's the reason is.When i checked my sound bar it shows Digital Output Device(SPDIF) is connected.When i open the playback device screen it shows Speakers with red down arrow in it and displays not plugged in.But when i select it check its properties the status shows they are working properly.But my headphones are working properly.Please help me anyone to solve my problem.Thanks in advance..
Old 08-26-2009   #2 (permalink)
Xp-Vista-7
Re: Speakers not working
So, you have sound on your headphones but not your speakers. Is this correct?
If that is correct then you may have a loose wire to speakers or a short (meaning somehow somwhere the wires are crossed).
Or, you may have switched off your speakers via the sound Icon on the playback screen.
external speakers not working/pc has internal speakers Sound & Audio
Speakers 5.1 not working with WMP Vista music pictures video
Speakers aren't working Vista music pictures video
Speakers not working.... Vista hardware & devices
Only 2 speakers working? Vista music pictures video
