| Windows Vista | I need help with WMP 11 Windows Media player works fine for me. The only thing I have a problem with is when I play a dvd there is no audio but the video does show can anyone help? |
| Vista Home Premium 32bit OS / Sp2 | Beside no sound when playing dvd though WMP .... Does it have sound when you watch you-tube ...or dc music .....? |
| Windows Vista | yes for some reason only dvds. when i play a video file it does work fine. |
| Vista 32 win 7 7600 32 bit | |
| Windows Vista | well i mostly play avi. and wmv. i don't know of others yea i do play them in wmp |
| | #6 (permalink) |
| Vista 32 win 7 7600 32 bit | Mexicano And the dvd player did work under a previous OS like xp? If you play a music cd do you get sound?. Im just rying to figure out if it is a system problem or hware problem Hope this helps Ken |
| | #7 (permalink) |
| Windows Vista | i dont have an xp. when i play audio cds there is sound |
| | #8 (permalink) |
| | #9 (permalink) |
| Windows Vista | how do i find that out? |
| | #10 (permalink) |
