Vista - Sound & KB929685
Old 09-07-2009   #1 (permalink)
Vista Home Premium 32bit
Sound & KB929685
Hello.
Im pretty sure this question is already asked many times, but i hope you will forgive me and try to help me out anyway...
So... Im using windows vista home premium 32bit, like many people i had same problem with my audio... After hibernate|sleep status, then restart, and sound -> gone. I heard that i have to download and isntall KB929685 to fix that. The problem is when im trying to install this "KB929685" it give me error "The updates does not apply your system", so im asking for any other way fix my sound, or solution how fix this error.
Thanks.
Old 09-07-2009   #2 (permalink)
Vista Ultimate x64 SP1
Re: Sound & KB929685
Hi kam,
If you have Vista SP1 installed, than the patch you're trying to install is already included in SP1, thus "The updates does not apply your system" notification.
Hotfixes and Security Updates included in Windows Vista Service Pack 1.
As for your sound problems, can't help you there since you've provided no system specs.
Old 09-11-2009   #3 (permalink)
I was searching around all internet... Updates Drivers, Re-Installes Drivers, Re-Installed all Realtek... KB929685 cant install, and still there are no sound. Right now im really pissed becuase, i tryed so much things for nothing. Why the hell i had to pay for license if this vista even not working -_-. Howerver, enough those annoying answers that doesnt help, i want at last hear any answer that really may help. And yes all devices are enabled, checked more than 20 times...
Solved No sound when playing music or video, but internet sound works fine Sound & Audio
Sound Problems - Vent, Xfire, Steam voice - no sound Vista hardware & devices
Setting per Application Sound Output, or Per Sound Type Outputs... Vista General
My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! Vista General
Vista x64 RC2 - Sound Card/Amplifier - DTS Test Sound (Audigy 2 ZS SPDIF) Vista General
