Vista - HELP! My sound just went out 64 Bit
Old 09-07-2009   #1 (permalink)
Vista Home Premium 64 Bit
I am running Windows Vista Home Premium 64 Bit.
Everything has been working great on this computer for the past 2 years and suddenly my sound went out today. I thought it might be my headset going bad so I plugged my speakers in but they didn't work either.
I went into Device Manager and it says that my PnP Audio Device is working fine, but it obviously isn't.
Any help would greatly be appreciated.
Old 09-19-2009   #2 (permalink)
All versions of windows vista
Re: HELP! My sound just went out 64 Bit
Have you check the sound driver of your laptop??
It could be that you sound driver is genuine for 32 bit only.
Try uninstalling and reinstalling the sound driver.. it works most of the time..
distorted sound in vista/createiv x-fi titanium sound card Sound & Audio
Solved No sound when playing music or video, but internet sound works fine Sound & Audio
Setting per Application Sound Output, or Per Sound Type Outputs... Vista General
My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! Vista General
Vista x64 RC2 - Sound Card/Amplifier - DTS Test Sound (Audigy 2 ZS SPDIF) Vista General
