| Vista Home Premium 32 bit. | Help me?! ok my sound is freaking me out and i got other problems that just started happening. MY sound is all the way off but i can still hear it through my speakers. and Now Norton is randomly doesn't work and it wont let me do any windows updates. So i dont know whats going on but I need help. |
| Windows 7 Ultimate x64 | Re: Help me?! I suggest you do a virus scan. |
| vista home premium 32bit | Re: Help me?! Hi seantho If your norton is not working, go to this link, we have some very good lads. Norton Community - Norton Community |
| Vista Ultimate 64-bit, SP2 | Re: Help me?! ok my sound is freaking me out and i got other problems that just started happening. MY sound is all the way off but i can still hear it through my speakers. and Now Norton is randomly doesn't work and it wont let me do any windows updates. So i dont know whats going on but I need help. If your Norton is failing & you can't get any Windows Updates you may have malware.[or a virus.] It would be a good idea to run SuperAntiSpyware & Malwarebytes to see if they find anything. Both programs have a free version. Reboot after scanning finishes. Post back results. SUPERAntiSpyware.com | Remove Malware | Remove Spyware - AntiMalware, AntiSpyware, AntiAdware! Malwarebytes.org |
