Vista - Audio CD won't play on other devices.
Old 10-13-2009   #21 (permalink)
Vista Home Premium 32bit
Re: Audio CD won't play on other devices.
Just reread the part that says. "I may be totally off the track".
Ignore the rest.
Old 10-13-2009   #22 (permalink)
Vista Home Premium 64 bit
That's what I did originally, but I wan'ted to give you the benifit of the doubt and re-read it. What do you think about the 64 bit OS?
Nick
Old 10-13-2009   #23 (permalink)
I suggest converting the wma files to .wav files, before
burning to disc.
See if that works.
Old 10-13-2009   #24 (permalink)
What? Convert them to .wav then to cda?
Old 10-13-2009   #25 (permalink)
No, I meant just put them on the CD as .wav files.
( But don't forget this,"I may be totally off the track")
Edit. Sorry I mean just let the Roxio convert to cda
as part of it's process, but use .wav as source files.
Old 10-13-2009   #26 (permalink)
Then I have to convert from wma to wav? With what?
Nick
Old 10-13-2009   #27 (permalink)
It's been a while, but just tested this and it works.
Thank you for downloading Switch Sound File Converter from Download.com
Old 10-13-2009   #28 (permalink)
Really, what difference would it make burning a wma to a cda and a wav to a cda?
Nick
Old 10-13-2009   #29 (permalink)
Maybe none. It's just that .wav has been in use longer and may be compatible with more players than .wma.
Old 10-13-2009   #30 (permalink)
Windows 7 Ultimate x64
WMA won't work on most devices. Use .mp3, but its up to the device. Rip your cd's if you don't burn copies of them losslessly if your pc has enough space.
Devices>Recording: "No Audio Devices Found" Sound & Audio
USB devices won't auto play Vista hardware & devices
plug and play devices Vista hardware & devices
usb plug and play devices Vista hardware & devices
plug n play devices Vista hardware & devices
