Vista - Audio CD won't play on other devices.
Old 10-14-2009   #41 (permalink)
Vista Home Premium 64 bit
Re: Audio CD won't play on other devices.
They play on a newer player just fine. How do I convert everything over to lossless, or how do I check if they are?
Old 10-14-2009   #42 (permalink)
Windows 7 Ultimate x64
Rip a cd to wma lossless if you use WMP for storage, or rip to mp3 for easy burning. I wouldn't go below 192/kb. If you don't use WMP try FLAC and Jajuk jukebox.
Old 10-14-2009   #43 (permalink)
OK, I've done all this. Do you realize my plite?
Old 10-14-2009   #44 (permalink)
? What are you getting at? My contact details are in my profile if you need them.
Old 10-15-2009   #45 (permalink)
32bit vista home premuim-SP2
Quote  Quote: Originally Posted by caddman6425 View Post
I just don't understand what's going on. This is a brand new computer and WMP, I would believe, would be setup for it. On the other hand Roxio might not be, since it was on my last computer which was a 32 bit OS. Like I said before, the DVD Player/Recorder will play them all, but the DVD players won't, or the car CD player won't. It is funny that if I can burn a CD on a 32 bit system and it works fine on all players and if burned on a 64 bit system, and it only plays on the newest player that it has to do with something with the 64 bit system, but the firmware? I just don't know!
Nick
What version of Roxio are you using and have you gone into their site to see if any updates are pending for Vista 64??
Can Roxio be set for Vista 32 compatibility?
Devices>Recording: "No Audio Devices Found" Sound & Audio
USB devices won't auto play Vista hardware & devices
plug and play devices Vista hardware & devices
usb plug and play devices Vista hardware & devices
plug n play devices Vista hardware & devices
