Vista - I have no sound.
Old 10-03-2009   #1 (permalink)
32bit
I have no sound.
I think I must have downloaded an update, because there is no sound on this computer anymore.
I need to stop touching my computer; but I need some help.
I have a Compaq V6000 and I have no sound. Nothing.
The only thing that has sounds are the buttons to turn the volume up and down and mute button and the other button.
No I do not have my sound muted.
Help?
Old 10-03-2009   #2 (permalink)
Windows Vista Enterprise x64 SP2
Re: I have no sound.
Please check your device manager to see if there is a question mark or exclamation mark by your sound.
Just type "device manager" in your START window to begin.
Old 10-03-2009   #3 (permalink)
Is it a v6000 au, cto, ea, us, xx or cl?
Old 10-03-2009   #4 (permalink)
32bit
Au
And there isn't anything like that beside it. It says it's working fine too.
Old 10-03-2009   #5 (permalink)
First - Check mute button on your notebook. Was this the problem? If not, proceed...
Second - What update did you install? Can you rollback to uninstall this update?
Third - Please flash your bios, update drivers...
Select software and drivers Compaq Presario V6000AU Notebook PC - HP Customer Care (United States - English)
Old 10-03-2009   #6 (permalink)
Ubuntu 9.10 64 Bit
I know when Vista updated my IDT sound driver it stopped my sound from working. I wonder if thats the case here. When you say update, did you allow Windows to update the sound driver for you? If you did then use the link lemur gave you and download the latest driver, then install that.
Old 10-04-2009   #7 (permalink)
Vista Home Premium 64bit SP2
sorry i couldnt resist , and im a bit bored
Old 10-04-2009   #8 (permalink)
Ya I never trust Windows to find the correct driver.More often than not it will give you the wrong driver or say you're driver is fine even when its like 4 years old
Solved No sound when playing music or video, but internet sound works fine Sound & Audio
Sound Problems - Vent, Xfire, Steam voice - no sound Vista hardware & devices
Setting per Application Sound Output, or Per Sound Type Outputs... Vista General
My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! Vista General
Vista x64 RC2 - Sound Card/Amplifier - DTS Test Sound (Audigy 2 ZS SPDIF) Vista General
