| | #11 (permalink) |
| Vista Home Premium 64bit | Re: no balloon sound Ahh ok sorry again man I was feeling terrible I didn't mean to be a jerk 9/10 times k-lite does fix Windows sounds and WMP.I'll look around some for you and post a couple fixes I hope they work TBH I have a notoriously bad temper but I usually have a good handle on it.Wait you already fixed it ? Sorry I'm very easily sidetracked and high strung Let me know I'll check back here later.I hope you got it fixed gj Thx again for being understanding and patient with me. Last edited by blue75; 10-10-2009 at 02:10 PM.. |
| | #12 (permalink) |
| Vista Home Premium 32bit | Re: no balloon sound Thanks man but no need.... ______________problem is solved__________________ |
| | #13 (permalink) |
| Vista Home Premium 64bit | Re: no balloon sound Sweet nice work |
| balloon tips | Vista General | |||
| Balloon tips | General Discussion | |||
| System Notification / Windows Balloon Sound Not Working | Sound & Audio | |||
| Balloon Tip | PowerShell | |||
| No balloon sound | Vista General | |||
