Vista - Vista 64 Audio Problem?
Old 10-14-2009   #21 (permalink)
Vista Home Premium 64
Re: Vista 64 Audio Problem?
well, I've tried to install the realtek drivers, but nothing happens. I run the setup, it tells me to restart and there's nothing. Device manager still says the same. and No new options under any sound file.
Old 10-14-2009   #22 (permalink)
Windows 7 Ultimate x64
In device manager choose update driver and locate the unzipped drivers in a local search. Then reboot.
Old 10-14-2009   #23 (permalink)
and Lemur, when I click on "High Definition Audio Device" this is the info it gives me, did I click on the right thing? I didn't have a tab for sound, only sounds under devices.
Property Value
Device ID HDAUDIO\FUNC_01VEN_11D4DEV_989BSUBSYS_10438372REV_1003\418DBCFAE00001
Status 0x0180200a Started
Problem 0x00000000 (0)
Service HdAudAddService
Capabilities 0x00000000
Config Flags 0x00000000
Class MEDIA
Manufacturer Microsoft
Hardware IDs HDAUDIO\FUNC_01VEN_11D4DEV_989BSUBSYS_10438372REV_1003
Compatible IDs HDAUDIO\FUNC_01CTLR_VEN_8086CTLR_DEV_3A3EVEN_11D4DEV_989BREV_1003
HDAUDIO\FUNC_01CTLR_VEN_8086VEN_11D4DEV_989BREV_1003
HDAUDIO\FUNC_01VEN_11D4DEV_989BREV_1003
HDAUDIO\FUNC_01GFVEN_11D4DEV_989BSUBSYS_10438372REV_1003
HDAUDIO\FUNC_01
Class GUID {4d36e96c-e325-11ce-bfc1-08002be10318}
Location Internal High Definition Audio Bus
Bus number 0x00000000
Enumerator name HDAUDIO
Description High Definition Audio Device
Driver {4d36e96c-e325-11ce-bfc1-08002be10318}\0000
Physical Object Name \Device\0000005a
UI number 0x00000000
Bustype GUID {41203534-2037-3144-2042-422044362041}
Legacy bus type 0x00000005
Device Type 0x0000001d
Install State 0x00000000
Security 01 00 04 90 00 00 00 00 00 00 00 00 00 00 00 00 14 00 00 00 02 00 5C 00 04 00 00 00 00 00 14 00 00 00 00 10 01 01 00 00 00 00 00 05 12 00 00 00 00 00 18 00 00 00 00 E0 01 02 00 00 00 00 00 05 20 00 00 00 20 02 00 00 00 00 14 00 00 00 00 E0 01 01 00 00 00 00 00 01 00 00 00 00 00 00 14 00 00 00 00 E0 01 01 00 00 00 00 00 05 0C 00 00 00
Security (SDS form) D:P(A;;GA;;;SY)(A;;GXGWGR;;;BA)(A;;GXGWGR;;;WD)(A;;GXGWGR;;;RC)
Device Address 0x00000001
Device Configuration File hdaudio.inf
Driver HdAudio.sys
DisableSetupDiChangeState 00 00 00 00
InfPath hdaudio.inf
IncludedInfs ks.inf
wdmaudio.inf
InfSection HdAudModel
ProviderName Microsoft
DriverDateData 00 80 8C A3 C5 94 C6 01
DriverDate 6-21-2006
DriverVersion 6.0.6000.16386
MatchingDeviceId hdaudio\func_01
DriverDesc High Definition Audio Device
KS 1
Class MEDIA
ClassDesc @mmci.dll,-3000
Sound, video and game controllers
IconPath %systemroot%\system32\mmsys.cpl,-3004
LowerLogoVersion 5.1
Installer32 mmci.dll,MediaClassInstaller
UpperFilters ksthunk
Old 10-14-2009   #24 (permalink)
Do you see this:
Old 10-14-2009   #25 (permalink)
It doesn't give me the option to update drivers in the device manager. I can uninstall and then it finds it again, or I can disable. There's no other option for updating drivers. When I search for drivers in the file where i saved realtek, it searches and then says the device is up to date. And when I pick from a list, thats the only one selectable.
Old 10-14-2009   #26 (permalink)
Mine just says High Definition Audio Device under sound and video game controllers.
Old 10-14-2009   #27 (permalink)
What does dxdiag say when you enter that into the start menu, in the sound tab - what date for the driver?
Old 10-14-2009   #28 (permalink)
The date is 6/21/2006. and what do you mean? Dxdiag when I enter what into the start menu?
Old 10-14-2009   #29 (permalink)
If thats the date the update wasn't installed. You sure you can't right click the entry in device manager and choose update?
Old 10-14-2009   #30 (permalink)
Positive. I can't update it that way no matter if I choose search the internet or browse my computer.
Vista x64 Audio Driver Problem ! Sound & Audio
Realtek HD Audio mic playthrough problem in Vista Sound & Audio
Vista audio problem with X-Fi Vista hardware & devices
Audio Problem With Vista Ultimate Vista hardware & devices
Vista WMP 11 to XBox 360 audio streaming problem Vista music pictures video
