Vista - Crackling Sound - Audio
Old 10-18-2009   #11 (permalink)
Vista Home Premium x64
Re: Crackling Sound - Audio
Quote  Quote: Originally Posted by zigzag3143 View Post
Quote  Quote: Originally Posted by Pavilionator View Post
I have been researching in in google and found this page. Same problem same model, they have had to send the computer back to hp. its here Re: dv4-1028us notebook HDMI audio popping and crackling - Notebook PC Sound and Audio - HP Support Forum . this is HP support forum and the problem stems from the audio and another device.
Let me know if this doesn't help
Ken
Thank you so much, I'll try the safe mode start-up again and if that don't work I'll contact HP
Did this do this from the start or just recently? If I read the HP site correctly its a conflict between the audio and a broadcom driver. before you send it back try to re-install that driver. Might work, might not but it cant hurt
en
It's been happening since I got it, even after I replaced it once
Old 10-18-2009   #12 (permalink)
The safe mode method seems to be working, for now. Thanx again for the help
Old 10-18-2009   #13 (permalink)
Vista 32 win 7 7600 32 bit
so not crackling in safe mode? if not we can fix this
Old 10-18-2009   #14 (permalink)
I uninstalled the driver in safe mode and rebooted. It got reinstalled automatically and now it works fine
Old 10-18-2009   #15 (permalink)
So you are fixed. Congrats on the fix
Ken
Crackling & Hissed AUDIO Sound & Audio
sound crackling! Sound & Audio
crackling surround sound Sound & Audio
Bagof Wi (n.d) Crackling Sound Graphic cards
Crackling sound Sound & Audio
