Vista - How to remove empty Vol. mixer bars?
Old 4 Weeks Ago   #11 (permalink)
Re: How to remove empty Vol. mixer bars?
That was a statement by me based on observation. Vista and Windows 7 both seem to have space for 4 volume levels by default.
Old 4 Weeks Ago   #12 (permalink)
Vista Home Premium 32bit
OK,
you are the MVP and have the experience.
i consider this issue as solved.
thanks again .
Old 4 Weeks Ago   #13 (permalink)
No problem Prukeyhi. There just does not seem to be a way to change this.
Remove empty folders in C:\Windows\Temp ?? Vista General
remove all empty folders PowerShell
file folder icons display non-empty folders as empty Vista file management
Remove empty folders PowerShell
Can I Permanently Remove Empty Removable Drives? Vista hardware & devices
