Stiff Richard
sygnus21...You are a GOD...without the appropriate bowing. I have been stressing for 3 solid days since I installed Windows 7. I have been unable to use and hear sound (through 'test' or 'monitor') using my mic in Ventrilo. So many forums speaking about which client version to use in order for my sounds of joy to be heard when I all of a sudden happened onto this forum with your praises of the Titanium Fatal1ty sound card from Creative. It worked just fine with XP x64 via the simple 'Line-In' 3.5 mm jack on the card, but did not work with Win7. But like you explained about the AC '97 hook up from the FP, which was something I used in my final google/yahoo search, wolla (or viola, depending on where you heard it first) I HAVE VOICE.
Thank you very much for your article/post.
AMD Phenom II 965 3.4 gHz
ASUS Crosshair Formula III
Creative Titanium Fatal1ty
Dual Sapphire 4890 OC 1 gig DDR5
Muskin 8 gig (4x 2 gig) Ram
Antec 1200 Gaming Case
Windows 7 x64
Yeah, she's a runner.
Windows 7 x64
