Sound card help
Cowz
I just got the Razer Barracuda headset and I wanna get the most sound out of it.
Now on the back the out ports work for all the wires but when I try to plug into the mic one on the back it doesn't. So I`m either suck with a mic that sounds like i`m miles away and great sound, Or i`m with a great mic and decent sound(just front speakers).
It works on the front however but on the front there is only room for a front speaker. Is there a way around this?
Dell XPS 420
Vista 32
This is what it says in the owners manual about the ports
1 microphone connector
-Use the microphone connector to attach a personal computer microphone for voice or musical input into a sound or telephony program.
Now the only line in connect on the back
9 Line in connector
-Use the (Blue) line-in connector to attach a record/playback device such as a cassette player,CD player, or VCR.
Razer Barracudaâ„¢ HP-1 5.1 Channel Gaming Headphones | Buy Online
Pages 19-21
Front I/O Connectors - Owners Manual - Dell 420
If I am reading this right, why are you trying to connect a 5.1 headset to the stereo front panel connector? To connect it properly you need to connect it to the front/rear/center ports on the sound card (whether onboard or an actual sound card),
including the USB connection which I assume is to power the built-in amplifier.
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech Wave
    Logitech G5 v2
Well the thing is I want my Mic to work as well. The in on the back does not work that's why I posted the difference in them. The only one that works for a mic is the front one. I am wondering if there is a way around thing to where I can get the 5.1 sound and the mic to work at the same time. My other option was just to connect the front speakers on the front I/O port and have my mic work.
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Antec Sonata III
    Logitech Wave
    Logitech G5 v2
