how to change audio port
givenup
guys i miss the old audio manger
when it pop's up a balloon asking you what that port will be
i need to change my computer rear line in to headphones or speakers
any way to do it ?
Right click on the speaker on the taskbar, select playback devices, and change it from there.
    Intel I5-2500K @3.3GHz
    Asrock P67 Extreme4
    EVGA GeForce 750 Ti SC 2GB
    auria eq2367
    250GB Samsung 850 EVO SSD
    1TB WD Blue
    1TB Hitachi
    SeaSonic X 650W 80 Plus Gold
    Corsair Obsidian 750D
    Logitech Wireless Mouse M310
    Laptop specs: HP g7-1365dx /
    CPU: AMD A6-3420M APU with Radeon(tm) HD Graphics /
    RAM: Crucial 8Gb (2x4Gb) /
    SSD: Crucial M4-CT128M4SSD2 ATA Device/ FW 000F /
    GFX: AMD Radeon HD 6520G /
    OS: Windows 10 Pro x64
the question is how ???
any way to do it ?
I may have misunderstood you, are you trying to make your LINE IN work with headphones or speakers?
Line In is for a microphone, if I am misunderstanding you I apologize.
Also if you could give us some specs about your computer, This little app here Speccy - System Information - Free Download will help with that.
    Asrock P67 Extreme4
    auria eq2367
    1TB WD Blue
    1TB Hitachi
    Asrock P67 Extreme4
    auria eq2367
    1TB WD Blue
    1TB Hitachi
thanks but no use
i have three connector and speaker and microphine and line in
i'm using line out for speaker (the green one)
i'm using the MiC for the microphone (the red one (pinkish))
and the line in or the blue one i need to change it form line in to line out (like the green one ) in the old days on XP when you connect a device it show you a dialog box to chose what is the device (line in , Mic ....)
and there for i need to connect a head phone to the line in
Sorry but I can't seem to find a fix for your problem.
Here is the motherboard listed in your specs.
Maybe someone else can shed some light on this for you.
It sounds to me like you want the audio manager back, You may want to do a search for that.
Sorry I couldn't help you.
    Asrock P67 Extreme4
    auria eq2367
    1TB WD Blue
    1TB Hitachi
You're Welcome, If I find something I'll let you know.
    Asrock P67 Extreme4
    auria eq2367
    1TB WD Blue
    1TB Hitachi
What brand and model is your computer. Maybe we can find something from their website.
    Asrock P67 Extreme4
    auria eq2367
    1TB WD Blue
    1TB Hitachi
I don't remember ever being able to change a Line In to a Line Out in Win 95. They're hard-wired for particular circuit paths.
Just go to Radio Shack and get a line splitter for your Line Out jack.
-!Dual%20Headphone%20Jack%20Splitter%20Stereo%203%205mm%20Y%20Adapter%201%20Plug%20To%202%20Jacks%20Cable--12146137.jpg
The cannon sound is in your sounds control panel. Go to Control Panel, select "Hardware and Sound" and, under the third header, "Change system sounds."
In the Classic View control panel you just click "Sounds" and go to the third tab.
Hit the "Windows" header at the top of the list with your mouse key once, and then scroll down the list with your Down Arrow key. You're scrolling down all possible sounds Vista OS plays. Any of the basic system sounds like "Low Battery Alarm" or "Device Disconnect" that doesn't say "Windows..." in the sound scheme is what you're looking for.
    Hewlett-Packard dv6936us
    Intel Core 2 Duo "Merom" T5750, 2 GHz, stock clocking
    stock Quanta 30D2, v.792E
    4 GHz, 667 MHz bus speed
    NVIDIA GeForce 8400M GS, stock
    stock Realtek software-based
    stock 15.4" widescreen
    stock 1280 X 800
    stock Toshiba MK2546GSX and a Western Digital 1TB MyBook
    stock
    stock
    stock plus Rocketfish model RF-LAPCOL
    stock
    stock Synaptics Pointing Device
    Ludicrous Speed (~10.9 Mbps, more or less)
    Browser: Namoroka v1.9.2.3666 64-bit build. Computer specs:
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01485288&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&product=3747246
    I like chocolate milk!
-%21Dual%20Headphone%20Jack%20Splitter%20Stereo%203%205mm%20Y%20Adapter%201%20Plug%20To%202%20Jacks%20Cable--12146137.jpg
i think that the splitter is the only way
my computer i build it my self so nothing can be found i will try talking to asus support if they could do something
sorry for being late
input and outputs are different.. you can't just suppose you can change them.
    t7200
    some chinese junk (microstar i think)
    1GB
    gma 950
    internal intel hda
    Seagate 80GB, 7200rpm (2.5")
    me
    20 Mbit/s duplex
