REAL PLAYER VOLUME Level Poor When Playing Downloaded Video
Imperfect1
I really like the "Download this Video" link in RealPlayer, because it will download any movies or videos from the web --- but when I play the movies/videos in RealPlayer, the maximum volume is way too low. I've downloaded the most recent IDT Codec, and made all the volume and IDT sound/volume adjustments I can think of -- but nothing seems to help. Can anyone offer any suggestions?
    HP Pavillion dv5t (Gen. 1)
    1680 x 1050
    built in - HP
    max
No RealPlayer users in the crowd? Or am I the only one with this problem?
    1680 x 1050
    built in - HP
    max
Hello Imperfect1,
Have you tried turning up the volume in Media Player using the Graphic Equaliser ?,
Also, take a look at this piece of software, it may help.
Volume Logic for RealPlayer 1.3.1
I don't know how much help this will be, but i hope it helps a bit. Good luck.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    300 Gig Maxtor, (External)
    CoolerMaster 1000
    Logitech G15
    Logitech G5
    20Mbps
Hello Imperfect1,
Hi Stoneys-Nutz, thanks so much for responding and for the great suggestions. I hadn't tried the RealPlayer equalizer, so I just did, and it helped a tiny bit. Not much, but a little. So I'm going to try Volume Logic next. Wish me luck! And thanks again.
    1680 x 1050
    built in - HP
    max
Check the audio mixer( right click the speaker icon on task bar) and see the level for wave(for real player) if its set too low you always hear low volume.
    vnbv
    nkjnk
    knklj
    knlk
    nlkn
    mnkln
    lknl
