no audio output device is installed!
Hello,
I have Hp Compaq Presario F700, my sound card is not working anymore. It says no audio output device is installed. Unfortunately, there is no "sound, video and game controllers" in device manager, and also my sound device is not seen in device manager. My sound appeared a few days ago, but after a restart it has gone again. I tried to install the driver over and over again, but it says "could not find MEDIA device for this driver" I don't know what to do! Please someone help me.
My Operating System is Vista.
AUDİO: Conexant HD-Audio SmartAudio 221
Go into device manager and show hidden devices. This is in the view menu.
Are there any devices with a red cross or yellow exclamation mark next to them?
Try doing a restore to a time before this started to happen.
Are you using the 64 or 32 bit drivers?
Here is the HP page for your laptop and all the drivers.
Compaq Presario F700 Notebook PC series
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Logik
    Technika TKOPTM2
    Creative Inspire 7.1 T7900 Speakers
    Trust Graphics Tablet
Thank you for your reply. I've already gone into device manager and there are no devices with a red cross or yellow exclamation mark. Unfortunately, I can't do the system restore to the time problem appeared, because I've took my pc back to the factory settings in order to solve the problem but it did not. I'm using Vista 32 bit. I've already tried to update the drivers from hp web page, but as I said before, as I want to update the sound driver, it says "could not find media device for this driver" The system doesn't see my sound card, that's the main problem, so that I can't update the driver which a system doesn't see.
I have been looking into this and the only person I found with a solution was this guy.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
Thank you for your response but unfortunately I've tried that before, however my sound card is can not seen at bios cause it is not onboard I think.
Have you tried the add hardware wizard it might find it.
    LENOVO 64734VM
    15 inch
    External Speakers
I don't want to give you any bad news but if the bios didn't have the option to enable sound it may be a workshop job.
    LENOVO 64734VM
    15 inch
    External Speakers
It may not be that bad, because I guess not all the computers have the option to enable/disable audio function in bios, it depens on the sound card is on board or not if I am not wrong. For example, also my brother's pc doesn't has the option to enable/disable sound, and he hasn't got any problems with his pc.
I think you might need to do a repair install. Could the sound card be damaged?
    LENOVO 64734VM
    15 inch
    External Speakers
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Logik
    Technika TKOPTM2
    LENOVO 64734VM
    15 inch
    External Speakers
