External speakers won't work
largal
I tried the sfc/scannow and a reboot to no avail. My external speakers work in test but not with a youtube etc. video. If i go to control panel>speakers>right click on realtek speakers.select show disabled devices>configure I get the windows cannot find rundll 32.exe\system 32 message...help
Re: Windows cannot find c:\windows\system32\rundll32.exe
I tried the sfc/scannow and a reboot to no avail. My external speaker work in test but not with a youtube etc. video. If i go to control panel>speakers>right click on realtek speakers.select show disabled devices>configure I get the windows cannot find rundll 32.exe\system 32 message...help
It's .... rundll32.exe ...... ONE WORD
system32 ........ ONE WORD
Just for the heck of it, would you mind try this ?......
Start > in the search box, type system32 > press Enter key > in the System32 window, top right, in the search box, type rundll32.exe
Does the system find it ?
  • Other Info
    WLM 2011
    IE9 beta
Is it happening only for youtube? or anything with IE?
Does it work fien when playing music from Windows media player..
Open youtube and on the bottom right hand corner of your bottom toolbar click on the volume icon and open "mixer" check if "youtube" is not set to "mute" by mistake..
Hello largal,
Welcome to Vista forums.
Have you tried re-installing the drivers for your speakers?
You can do this through your Device Manager.
    HP Pavilion Elite
    Some Amount of Motherness
    6.O GB RAM
    Some Amount of Soundness
    1440x900 & 1440x900
    WD Caviar Blue 500GB
    Some Amount of Voltageness
    Hp Pavilion Elite Case
    Some Amount of Coolingness
    HP: Model Number: KB0911
    HP: M/N:M-SBQ133
    Comcast: 20 MB/S
when I type in the search box and hit enter I basicaly get a blank page. the only thing it says is "did you find what you were looking for?" below that is an advanced search icon
One of the first things I tried was reloading the divers..No change..I have sound on the internal speakers and it works fine on any application that has sound. the only time I can get sound to come out of the externals is when I do a test..
The only plug ins on the L305 are in the front. One for external speakers and one for earphones. the're both clearly marked...
