dvd drive
  1. #1
    Junior Member
    vista home basic 32bit
    Local Time: 05:13 PM
    dvd drive
    Hi, I seem to have a problem uploading my photo's to disc. When i r/click a photo & select burn to disc, a message comes up please put disk into drive e. i carry out the instruction put in the disc the drive closes then nothing happens. Am i missing an instruction? Thanks
  2. #2
    MilesAhead's Avatar
    Eclectician
    Vista Home Premium 64 bit SP1
    Local Time: 11:13 AM
    usa
    Re: dvd drive
    Everyone I know doing serious media burning uses this:
    The Official ImgBurn Website
  3. #3
    Junior Member
      Thread Starter
    Re: dvd drive
    Quote Originally Posted by MilesAhead View Post
    tried this but was refused as it could harm the computer. could you recomend another reader. Thanks
  4. #4
    MilesAhead's Avatar
    Eclectician
    usa
    Re: dvd drive
    If you are running anti-virus real-time shield software it's not uncommon for it to interfere with how the system functions. Imgburn has been around for quite awhile and has a top notch reputation. If it shows as malware and you downloaded directly from the Imgburn site, then the av software may be the problem.
    edit: it may be worth an experiment. If you have real-time av protection running, turn it off just long enough to try burning a disc. If everything works then that would indicate it's not letting the burning software properly access the hardware.
  5. #5
    Junior Member
      Thread Starter
    Re: dvd drive
    Thanks Miles I will give it a go thanks for your time.
dvd drive problems?
Recovery Drive almost full: Should backups be in D drive or in the C drive? o0Kara0o General Discussion 10 14 Jul 2010
Windows 2003: Replacing Drive with Boot.ini file. Can I move it toother drive? mitchkill Server General 6 15 Sep 2009
Access XP data drive using Vista Ult (XP drive=slave drive only NO John C (Go Packers!) Vista account administration 0 23 Jun 2008
Vista on the C: drive but System drive is the D: drive - any way to hinnc Vista installation & setup 4 15 Nov 2007
Vista maping drive to server 2000 shared drive not recognize user/ Sam Vista networking & sharing 1 02 Nov 2007
