No sound from my laptop.
  1.    27 Dec 2011 #1
    Yorkshire, UK.
    Vista Home Premium 32 bit
    Local Time: 11:45
    uk
    Using Dell Inspiron 1545 laptop. The volume icon is showing with a volume of :72 but there is no sound being emitted. I have been into the Control Panel, and checked the volume there, and everything is shown as being correct. So, what is the solution, please?
    Hope someone cmoes up with the remedy, as I had googled for instructions as how to use an Epson Perfection scanner. Found a video on YouTube, but naturally without sound I will get nowhere.
  2.    27 Dec 2011 #2
    Fairfield County, CT
    Windows 7 SP1 x64
    Local Time: 05:45
    usa us connecticut
    Re: No sound from my laptop.
    Welcome
    To me it sounds like a driver problem. I would go to search by the start button, type device manager and update all the audio drivers. Any drivers with a small yellow marker besides it, should, also be updated. If that does not work go to the website of the audio card and update from there. Wish you luck.
  3.    28 Dec 2011 #3
    Yorkshire, UK.
    Local Time: 11:45
    uk
      Thread Starter
    Richard, Thanks for the suggestion and I will give it a try.
  4.    29 Dec 2011 #4
    Yorkshire, UK.
    Local Time: 11:45
    uk
      Thread Starter
    Richard, Did not even get the opportunity to try your remedy, as the sound came back on unexpectedly. I have experienced the same thing on the odd occasion in the past. No sound, then it shows up again.
    I also experience the same thing with the battery/power icon. It disappears, then when entering the control panel I am unable to re-install the battery icon at the bottom right hand corner of the screen. Next day when starting up - enter the control panel, and it will then accept the tick in the power box, and the battery icon re-appears.
    Thanks, all the same though, and I will make a note of your suggestion for future use.
How to identify a laptop sound card after opening a laptop?
General Discussion
No sound from laptop
i have a hp pavilion dv7 laptop and i can not get any sound from it.The computer is telling me that the sound devices are working properly,i have...
Sound & Audio
Laptop no sound
I have had my laptop for a while and just rercently there was no sound. I had no problem with anything to with sound previously and then I installed...
Vista hardware & devices
no sound on laptop
I have a Dell XPS M1210 laptop with the Vista OS. My sound stopped working and I made no changes in audio settings nor did I load new software....
Vista music pictures video
No Sound From Laptop
I have no sound coming from my laptop. It does not play media files or any thing on the internet. Any suggestions? It shows that its working and I...
Vista General
Laptop Sound card + Vista - NO SPEAKERS!! + NO SOUND
I am using a laptop with a Realtek sound card, the devices show that the sound card is working but no speakers are plugged in. The system has not...
Sound on a Laptop
I have a Toshiba Laptop Satellite 1405-S151 my problem is i have sound when playing music for 1min and 7 seconds.I have a ALI soundcard does anyone...
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
