vista32 audio "stutter"
  1. #21
    tom982's Avatar
    ٩(͡๏̯͡๏)۶
    England
    Windows 7 Ultimate x64 SP1
    Local Time: 09:23 AM
    uk uk england
    Re: vista32 audio "stutter"
    Quote Originally Posted by shhhhharlotte View Post
    Hello. I don't want to be rude and hijack tooze's thread, but I have almost exactly the same problem. I have a Dell Inspiron 1545 (64 bit). The operating system has just been reinstalled and now the audio is stuttering. I was wondering if it was a software issue or if there is something wrong with the soundcard.
    Also, I tried uninstalling and reinstalling the driver and disabling enhancements. The SFC scan came up with no violations. I tried disabling all of the startup services and the audio seemed to be fine when I disabled the Intel Matrix Storage Manager. Could that be causing the problem?
    Hello and welcome to the forums
    Don't worry, it's not rude at all
    It would be best if you started your own thread This way the help you receive will be specific to your problem. Post a link to your thread on this thread and I'll come and have a look for you. This Intel Matrix Storage Manager revelation does sound interesting!
    Tom
  2. #22
    x64
    Local Time: 03:23 AM
    Thank you! Here is the link to the thread I started: Vista 64 Audio Stutter
Page 3 of 3 FirstFirst 123
SOLVED! "Cannot load Contacts" "0x8004104E" "MSOE.DLL" Samsara Vista mail 0 08 Jul 2009
Unwanted Multiple contacts in "To","CC","BCC" of email send catago xsailer Vista mail 2 12 Oct 2008
Vista not wotking with "My Computer" or "Control Panel", "Screen Saver" Platebanger Vista General 6 05 Feb 2008
How can I add the icons "Delete", "Cut", "Copy" and "Paste" in Vis Moonwalker Vista file management 7 17 Sep 2007
WM5 Sync with Vista "Windows Calender", "Contacts", and "Mail" Tony Vista General 1 16 Feb 2007
