No sound in Vista PLEASE help
  1. #1
    Newbie
    Vista Home Premium
    Local Time: 06:23 AM
    I recently moved and I did a proper shutdown on my computer, however when I set it back up at my new house I had no sound on my computer...not even the windows startup sounds.
    I have the on board Realtek AC'97 audio and I don't know if this is coincidence or not but I also noticed upon rebooting my computer that my I-Tunes was not longer installed...
    Here's what I have done so far..
    Checked for updated drivers( says I have the most up to date already)
    Uninstalled the Realtek and rebooted to allow Vista to reinstall it
    Reinstalled I-Tunes thinking perhaps something there had caused a problem.
    I have also written to Realtek tech support although I don't expect much from them.
    I have checked the device manager for yellow flags and there are none.
    Computer says the sound is working and the bar on my sound manager on my sys tray show sound but still nothing is coming from the speakers.
    I have tried other speakers and I have tried ALL sound plugins so even if I was plugging it in wrong, I have tried them ALL now....nothing is working.
    Any help would be massively appreciated.
    Thanks ins advance, Kevin
  2. #2
    Senior Member
    vista home premium
    Local Time: 07:23 AM
    Re: No sound in Vista PLEASE help
    I don't understand it at all but I occasionally get the same thing. The only thing I've found to work is to open Sound in Control Panel, make sure the speakers are set as the default and then select Configure for them. Then just start different variations of the settings. I have a 7.1 so I'll select that and check each speaker and, if they work, close out and Reboot. Sometimes I'll get sounds for some things and not for others but over time, everything mysteriously comes back. If that doesn't work, I'll go back in and change the settings back and forth (scientific isn't it? ). I also have a power switch for the speakers and sometimes just turning that off and on helps.
    Just some ideas. It's all a mystery to me.
    I have the same sound chip and software as you.
  3. #3
    Newbie
    Vista Home Premium
      Thread Starter
    Speakers are my only option on that screen so they are automatically default (set default won't even highlight).
    First time this has ever happened to me and I for one just don't understand it....by everything I know these speakers should be blasting.
    Any other help would be appreciated
    Kevin
  4. #4
    Newbie
    Vista Home Premium
      Thread Starter
    From everything I can see the sound is being produced but its not being sent to the speakers.....I know the speakers are working I hooked them up to my IPOD and they blasted.
    Frustrated to say the least
  5. #5
    Yard Dog's Avatar
    Senior Member
    Central Florida in a small town
    Vista Home Basic. 32 bit SP 2
    usa us florida
    Hello, sometimes using a different USB port will help out .
  6. #6
    Newbie
    Vista Home Premium
      Thread Starter
    tried that...NO HELP
  7. #7
    Yard Dog's Avatar
    Senior Member
    usa us florida
    When you open up your Audio Manager, sometimes, you have to just double check settings and such. I have had this issue before and it somehow, ( i have no idea what i pressed ) started working, when i did the test thing, boom. Had stereo and could adjust the equalizer and such.
  8. #8
    Newbie
    Vista Home Premium
      Thread Starter
    I've checked all the settings I know about but I will double check again
  9. #9
    Yard Dog's Avatar
    Senior Member
    usa us florida
    When you open up the Audio Manager , select the Sound Manager and then double check those.
  10. #10
    Newbie
    Vista Home Premium
      Thread Starter
    Checked everything I can think of I even checking things I KNEW couldn't be it just out of the frustration of it....how in the heck can it be generating sound and it not get to the speakers...KNOWING the speakers work
Page 1 of 2 12 LastLast
No sound in Vista PLEASE help problems?
distorted sound in vista/createiv x-fi titanium sound card badperson Sound & Audio 1 03 Sep 2009
Low sound from speakers and no windows sound on new vista Karen Vista hardware & devices 2 24 Mar 2007
Laptop Sound card + Vista - NO SPEAKERS!! + NO SOUND FriarTuck91 Vista hardware & devices 0 04 Nov 2006
My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! Kevin John Panzke Vista General 1 14 Oct 2006
Vista x64 RC2 - Sound Card/Amplifier - DTS Test Sound (Audigy 2 ZS SPDIF) Terje Alexander Barth Vista General 0 14 Oct 2006
