No HDMI sound or speak/headphones sound
Maxamillon
Hello , my sound isnt working at all i try to fix it but nothing. By fixing i mean unistall driver/ reinstall driver , tried the quick fix , did the realtek hdmi codec , device manager thing and nothing. This all happen because i tryed to update my radeon hd 5570 driver and i unistalled my sound driver but reinstalled them. (i already use driver genius to fix my display problem)
What happens if you make the Speakers the default?
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
Hello, do you have a restore point to go to , before this issue ?
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Have it restore you back to that date. See if your sound works. Post back please results of that .
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Peek in Device Manager again, Control Panel, Device Manager, see any yeller icons ?
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Give me make and model of computer, and in meantime , go to Microsoft updates and make sure you did not lose any of those in the restore you just did.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
My says what it is on my panels on my computer, do you not have anything that indicates what you are using for a machine ?
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
No, can you delete that please, privacy reasons , this is showing your product key.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
How bout downloading free version of Speccy and give me the motherboard info. ? Get free here : Speccy - Download
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
