Can't get any 5.1 sound to work.
  1. #21
    Junior Member
    Sweden
    Seven Ultimate x64
    Local Time: 04:51 PM
    sweden se stockholm
      Thread Starter
    Re: Can't get any 5.1 sound to work.
    Cannot find any such option.
    There are the following option:
    Important updates
    Recommended updates
    Who can install updates
    Microsoft update
    Software notification
    None of them have a non-Microsoft option.
  2. #22
    richc46's Avatar
    BSOD Squad
    Fairfield County, CT
    Windows 7 SP1 x64
    Local Time: 10:51 AM
    usa us connecticut
    Just make sure that all boxes are checked. Then with a System Restore point first, uninstall the driver. While on the internet, turn off the computer and boot. Go to device manager, you should have a new driver without any yellow markers.
    If there is not new driver, check to see if you have updates to install.
  3. #23
    Junior Member
    Sweden
    Seven Ultimate x64
    sweden se stockholm
      Thread Starter
    Just want to say that I'm a massive idiot, as I don't even have Vista, I have Windows 7, and should go to the seven forums and ask these questions... *hits forehead*
    EDIT: Or are you still able to guide me through this thing? =)
  4. #24
    richc46's Avatar
    BSOD Squad
    Windows 7 SP1 x64
    usa us connecticut
    I saw in an early post that you have Seven. I dont think this is a Vista or Seven specific problem. If we cannot get it done, you can try Seven, but I think we can get the speakers to work.
  5. #25
    Junior Member
    Sweden
    Seven Ultimate x64
    sweden se stockholm
      Thread Starter
    Sweet! Okay, I've set a restore point, and I'm going to uninstall the drivers now (Although they don't show any errors). Here we go!
  6. #26
    Junior Member
    Sweden
    Seven Ultimate x64
    sweden se stockholm
      Thread Starter
    Ok, it automatically updated the drivers to Realtek HD Audio, same driver version: 6.0.1.6602.
    Clicking Configure, under Speaker Setup/Audio Channels, it still only lists Stereo. No 5.1 sound. Clicking next gives me the abillity to check "Front left and right" whereas the "Surround speakers" option is grayed out. And I still do not have the Realtek Audio Manager in the control panel, so it seems nothing have changed.
    And Windows determined the drivers were up to date, too!
  7. #27
    richc46's Avatar
    BSOD Squad
    Windows 7 SP1 x64
    usa us connecticut
    OK
    This thread should help. Seems to be a similar problem with a number of options
    Realtek HD sound problems w/ 5.1 speaker [Solved] | Kioskea.net
  8. #28
    Junior Member
    Sweden
    Seven Ultimate x64
    sweden se stockholm
      Thread Starter
    Well, I can't set it up for 5.1 let alone 7.1, and I only have three connectors on the back of my computer. I don't have any speaker fill options either...
  9. #29
    richc46's Avatar
    BSOD Squad
    Windows 7 SP1 x64
    usa us connecticut
    I think the best thing that you can do is to post in Seven. Leave this thread and check both, this and Seven. We have one or two members here that may be able to provide a few more pointers, so dont give up on us.
  10. #30
    Junior Member
    Sweden
    Seven Ultimate x64
    sweden se stockholm
      Thread Starter
    I will try my luck there, thank you for your help!
    Oh, btw, is there still something I should try at the ASUSTeK website?
Page 3 of 4 FirstFirst 1234 LastLast
Sound does not work AngeredPally Sound & Audio 1 04 Oct 2010
Can't get sound to work Anne Gaddis Vista General 1 12 Sep 2007
5.1 Sound does not work Pb Vista music pictures video 1 29 Mar 2007
Help getting sound to work... Richard Wolff Vista General 2 15 Mar 2007
No Sound - No Drivers Work tommy Vista hardware & devices 13 16 Sep 2006
