No audio output device is installed
alba100
I recently had to reinstall Vista Home Premium 32bit.
I have everything back in place except the audio
The Audio is listed as a
5.1 CH windows vista premium level HD audio
(via vt 1708S audio codec)
and I believe is integrated into the motherboard.
I have a red cross beside the speaker icon on the task bar.
And when I hover it say
"No audio output device is installed"
However, when I go into the section of Device Manager under Sound etc
it is listed as High Definition Audio device
and using 'properties' it tells me the device is working properly
and has the correct driver
I have tried updating the driver,
I have uninstalled and reinstalled the device
I have search for new hardwear
I haver tried the microsoft repair tool to no avail.
It was working perfectly, I reinstalled Vista, and it ceased to work.
Any suggestion of where to from here would be appreciated.
Regards
    Asrock
    G31M-S
    integrated
    integrated
Hi alba100,
Let’s try run Microsoft fix-it to check if the services are enabled and drivers are installed properly: Automatically diagnose and fix Windows audio playback problems
If issue persists, please follow the link for detailed instructions: NO AUDIO OUTPUT DEVICE INSTALLED....OR RED CROSS IN BOTTOM RIGHT HAND CORNER ON VOLUME CONTROL
Also if issue persists, please provide me the following information:
1. Does the computer have external sound card?
2. Did you try to download the drivers from vendor’s website?
Please post the results.
    AMD FX-4100
    Gigabyte
    4Gb
    ATI 5450
    1600*900
    10Mbps
Thanks Madhur,
I think I have resolved the issue.
The Microsoft Fix it did not help.
I searched "via vt 1708S audio codec" and downloaded a driver from a third party,
which appears to have done the trick.
Unfortunately I did not note the site, before restarting, so I can't be specific.
Thank you for your help.
regards
    Asrock
    G31M-S
    integrated
    integrated
