I noticed there is no Windows Sound event for sleep
Cytherian
There's a sound event for Windows Logon and Logoff, as well as Windows Exit. But I don't see any for sleep (entering or waking). Is it possible to set a sound to trigger on those events? I know it will happen with Open Program, but then such a sound will be triggered for every program opening, which would be seriously annoying.
I did come up with a workaround for entering sleep. I use a wonderful command line utility called "nircmd". It has a "mediaplay" function, where you can play a sound for a set number of seconds. For sleep, I use a batch file and execute two commands, one to play the sound and then one to trigger sleep. But of course, there's nothing to be done for waking with this technique.
I searched around and found a couple of people interested in this, but the topics never end with a viable solution (often just abandoned). Any ideas?
    HP Pavillion dv5t
    Intel Core Duo 2.53GHz
    4Gb
    NVidia GeForce 9600M GT 512Mb
    1280x800 32bit
    Seagate Momentus XT 500Gb
    Hitachi Travelstar HTS543225L9A300 250Gb
    Microsoft 4000
