| | Vista - Latest Realtek HD Audio Driver Version |
| 07-21-2007 | #31 |
| Vista Home Premium x64 | Re: New Realtek HD audio driver update Yea I hear ya man. I am at about 20 hours. Off to bed myself. Thanks for all the help. |
| 07-21-2007 | #32 |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: New Realtek HD audio driver update Your welcome. |
| 07-21-2007 | #33 |
| Vista Home Premium x64 | Re: New Realtek HD audio driver update Ok so my mobo came with SoundMax HD audio software. Only problem is when I look online I can see that there is apparently a SoundMax manager but wherever I look for drivers for vista none of them come with the manager, they are driver only. So I am trying to figure out how on earth that is going to work. Also apparently according to my bios my front panel input can only be AC' 97 or HD audio, which I think is just preinstalled on vista. So with soundmax it doesn't recognize my front ports. Here is one last question. If I were to get a soundcard and just turn off in the bios my HD audio setup do you think it could run the same audio stream through my speakers and headphones at the same time and do you think my front panel would work? If not then crap, I screwed up with getting my mobo ! |
| 07-21-2007 | #34 |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: New Realtek HD audio driver update Sciz, You should be able to. Just make sure that the sound card has a compatible x64 Vista driver, has multi-streaming audio capability, and that it can plug the front panel into it. Check out the sound card at it's website and Google it before you buy it to see if it is what you want. I can't believe that it doesn't have a audio manager of it's own other than Vista's built in GUI manager. Last edited by Brink; 07-21-2007 at 05:40 PM.. |
| 07-21-2007 | #35 |
| Vista Home Premium x64 | Re: New Realtek HD audio driver update Man, so apparently it works with intel, but not AMD? Or maybe it only comes with intel mobos. I saw on their website information about the Soundmax driver and audio manager for the new Intel vista mobos. I doubt I could download that and put it onto my Asus AMD setup. That would be like crossing apples with oranges I suppose. |
| 07-21-2007 | #36 |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: New Realtek HD audio driver update Did you download the driver from Asus? http://support.asus.com/download/download.aspx?SLanguage=en-us Just cut and paste this below into the Input Model to Search in the upper left corner and press Enter: M2n32-SLi Premium Vista Edition Then select it (in the top middle) to see the list of drivers. Scroll through the list and you will see the audio ones. Shawn |
| 07-21-2007 | #37 |
| Vista Home Premium x64 | Re: New Realtek HD audio driver update Yea I did all that, and a bag of chips . I think I might just get a soundcard that will allow for front panel inputs. I just need to look at what I can get, I don't want to spend over $100 if I don't have to. I don't need crystal clear quality sound. BTW to have Realtek HD manager what is your setup? Like what mobo, processor and/or sound card do you have? |
| 07-21-2007 | #38 |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: New Realtek HD audio driver update Sciz, Realtek HD Audio was a integrated sound chip on my Intel D102GGC2 mobo. No PCI sound card. Nothing special required. The Realtek HD manager was just part of the driver software that came straight from Realtek instead of some OEM or mobo manufacturer. I have a Intel 64 bit 3 GHz P4. The computer itself is a eMachines T5048A. Not the T5048 as it was labeled LOL, but that is ok. The T5048A is much better. You can probably find a good cheap sound card at any computer store for what you need and want. Most of them are integrated into the mobo now. Shawn |
| 07-22-2007 | #39 |
| Vista x64 | Re: New Realtek HD audio driver update I find it ridiculous having to buy a soundcard in order to use my headphones the way i use them in Windows Xp. Is there a registry change where i can identify what i have connected??? Since i do not get this image as i do in XP ![]() Is there a way to manually enter the "values" on the registry to what i have connected on which plug??? |
| 07-22-2007 | #40 |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: New Realtek HD audio driver update Highlander, I can not believe I did not notice this little thing earlier. In the Realtek HD Audio Manager from Control Panel, look at the folder boxed in red below at the upper right corner. Click on it and it will open a window where you can check to enable that popup window to select headphones. Shawn |
Similar Threads for: Latest Realtek HD Audio Driver Version
| back panel not working for latest realtek driver! | Sound & Audio | |||
| Realtek AC'97 audio driver provided by Microsoft. Audio error MCE | Vista hardware & devices | |||
| Latest Creative Beta driver & the latest version of Skype | Vista General | |||
| Does the x64 version of Vista have driver for Realtek 8029AS? | Vista hardware & devices | |||
| Driver for Realtek HD Audio | Vista music pictures video | |||
