Vista - Latest Realtek HD Audio Driver Version
Old 11-13-2008   #481 (permalink)
Re: New Realtek HD audio driver update
Quote  Quote: Originally Posted by biertonco View Post
the whole driver thing confuses me when it comes to this. looking at my properties it says i have 6.0.1.5473 this most recent or?
the problem im having is that i get pop ups when im playing a game with my headphones. if someone speaks very loudly on ventrilo for example it will minimilize the game and a pop up will say i have disconnected a plugin. also my front port is always highlighted pink even when my mic isnt connected. any ideas/suggestions. thank you
Hello Biertonco,
It should have 6.0.1.5730 as the version number in Device Manager for the latest 2.08 driver.
Old 11-18-2008   #482 (permalink)
Vista Ultimate x64
R 2.09 is available but only the zipped version not the Exe. Any difference? Changelog?
Old 11-18-2008   #483 (permalink)
Thank you for the update rc213. The first page has been updated.
Both ZIP and EXE versions are available now.
Old 11-18-2008   #484 (permalink)
Vista Ultimate x64
Exe linked is Vista R 2.08 still.
Also, Just installed the zipped version but the Realtek Tray app doesn't come up.
Old 11-18-2008   #485 (permalink)
Vista Ultimate 64bit SP2/
Check to make sure display notification is dotted in the information button.
Old 11-18-2008   #486 (permalink)
Vista Ultimate x64
Quote  Quote: Originally Posted by mansrm81 View Post
Thanks, That seems to have done the trick. I will reboot once more to make sure it's working properly.
Old 11-18-2008   #487 (permalink)
Your welcome rc213
Old 11-20-2008   #488 (permalink)
Vista Home Premium 32-bit & Vista Ultimate 64-bit both Service Pack 2 W7 Pro RTM 7600 32 & 64
Thanks for the head up about R2.09, Shawn. The first run of the installation program uninstalled the current driver, as expected. I then restarted when prompted. Windows then proceeded to reinstall the basic driver that came with Vista (again, this was expected). However, on running the R2.09 installer again, it kept saying that the driver was already installed, except that I knew that it hadn't. To overcome this, I installed R2.09 directly via the 'Device Manager'. This needed to be carried out with administrative credentials. See the following Tutorial: Device Manager - Install Driver
Old 11-22-2008   #489 (permalink)
Vista Ultimate 64
Quote  Quote: Originally Posted by Majere View Post
After reading this thread (took about 203467 hours!!) I'm still not 100% on how to fix my problem, as it appears to be a similar problem to all here.
I have Vista Ultimate 64bit, with Realtek onboard sound on my mother board. However, my Quadraphonic speakers don't seem to be working as I can only get sound to come out of my front two speakers when in WMP etc. sometimes when I go into control panel, I can get sound coming out of all 4 speakers, but sometimes it doesn't happen. After reading this thread I have done the following:
1) Downloaded and installed the latest driver 2.08 (installed twice, forst time to remove old driver, next time to install new driver). My driver cersion is currently 6.0.1.5730.
2) Since installing the new driver, I have lost the Realtek icon in my control panel.
To be honest, I've used up all my, er, knowledge, does anyone have any ideas I can try?
Many thanks,
Maj
Anyone have any ideas on this problem, any help would be much appreciated!
Anyone have any idea how to fix this?
Old 11-22-2008   #490 (permalink)
Vista Home Premium x64
Many thanks,
Maj
How about completely uninstalling the audio driver, using a registry cleaner if you have one and then try installing again. In other words, you're trying to replicate a "clean" install.
Realtek HD Audio driver Vista music pictures video
back panel not working for latest realtek driver! Sound & Audio
Realtek AC'97 audio driver provided by Microsoft. Audio error MCE Vista hardware & devices
Latest Creative Beta driver & the latest version of Skype Vista General
Does the x64 version of Vista have driver for Realtek 8029AS? Vista hardware & devices
