Vista - Latest Realtek HD Audio Driver Version
Old 07-30-2009   #701 (permalink)
Vista Home Premium 32-bit & Vista Ultimate 64-bit both Service Pack 2 W7 Pro RTM 7600 32 & 64
Re: Latest Realtek HD Audio Driver Version
I use the method shown here Device Manager - Install Driver and have never had to go through the double installation routine.
Old 08-02-2009   #702 (permalink)
Vista Home Premium 32bit
Quote  Quote: Originally Posted by williamkane View Post
I have a problem here. I downloaded the latest drivers 2.29 (a zip file of size ~34mb that i downloaded from realtek website) and installed it. This is the first time I ever updated my audio drivers. After restarting, I observed the following scary changes:
1) I no longer see a realtek audio manager or that brown audio button on the bottom right system tray.
2) In the control panel I cant find any realtek related icons.
3) In the device manager, under 'sound, game, video controllers' - the sound driver's name is now high definition audio device instead of realtek high def audio device.
4) I no longer see a notification when I plugin my headphones. Sound comes out from the speakers until I change my audio preferences by making headphones as default everytime I plug it in.
5) I disabled the system restore so I dont have that option now, I tried seeing if I can uninstall this driver that I just installed from programs but It shows NO INSTALLATIONS on today's date. I searched for the word 'realtek' and it is no where except in the file I just downloaded.
So does that mean the udpate that I just installed didnt even get installed?..where is the realtek audio manager now??..Are these the ill effects of updating the driver?? ..
I use a 32bit vista system and till today the sound thing was just perfect...donno y this thought of updation came in ...now I am skeptical if the current sound quality is the same as the one it was before or it actually got a bit worse ..
PLEASE PLEASE Suggest a solution as soon as possible.
I have the same issue.
Old 08-08-2009   #703 (permalink)
Hi there,
when I choose 5.1 configuration in Sound Manager, the software enables "Sides" and disables "Rears" for surround speakers. This seems a bit strange to me, but is this normal for the Realtek software? I ask because if I plug my 5.1 analog speaker cables into the correct colour-coded output (black) this is for "Rears". To get sound from the surrounds I have to plug the black cable into the grey output for "Sides".
I thought the "Sides" where the extra speakers in a 7.1 config?
Can someone help me clear this up a bit?
Thanks
Dale
Old 08-11-2009   #704 (permalink)
New driver available, version R2.30 2009/8/11
Old 08-11-2009   #705 (permalink)
Vista Ultimate 64bit SP2/
Thanks Dwarf
Old 08-11-2009   #706 (permalink)
Yep, I've just noticed. Unfortunately, they aren't quite ready for downloading. It is a bit annoying when they do that - updating the site before they are ready. This is not the first time that they've done that.
Old 08-11-2009   #707 (permalink)
They are suppose to do it the other way not that way.
Old 08-11-2009   #708 (permalink)
Vista Home Premium 32bit [x86] - SP2
G'Day Fellas!!
Quote  Quote: Originally Posted by Dwarf View Post
Quote  Quote: Originally Posted by mansrm81 View Post
Thanks Dwarf
If these are my Driver details;
realtek-high-definition-audio-driver-v6.0.1.5717-dated-13oct2008.jpg.......
.......then when the new driver version mentioned by Dwarf is eventually made available, does it also automatically follow that I will be able to download and install it?
Or, does my current version mean that I will need to wait for an update from Windows, to update the driver to a later version?? I think that in the past, this latter method has been applied to my most recent Realtek Audio driver updates.
Your thoughts please.
Old 08-11-2009   #709 (permalink)
Hi Tony,
You should be able to download and install this version. I prefer to download and extract the .zip version, and then install as shown here Device Manager - Install Driver
Old 08-11-2009   #710 (permalink)
Hi Tony,
Thank a ton, Dwarf......reassurance is very helpful.
Realtek HD Audio driver Vista music pictures video
back panel not working for latest realtek driver! Sound & Audio
Realtek AC'97 audio driver provided by Microsoft. Audio error MCE Vista hardware & devices
Latest Creative Beta driver & the latest version of Skype Vista General
Does the x64 version of Vista have driver for Realtek 8029AS? Vista hardware & devices
