Stuck in Safe Mode and I have tried everything!
seashell
I am stuck in safe mode and have tried everything that the WIndows Vista Help and Support section recommends: F8 (normal mode, safe mode with netwroking etc), I have scanned and checked for virus, everything! Very frustrated, my husband thinks it could have happened after her tried to install something but he is not sure, I am pretty sure that whatever it was he tried to install was what did it as my son and I had not used the computer the day it got stuck in safe mode. He is not sure the name of what it was either.
What else can I try?
I'm not 100% sure on this 1 but a little research found me this
while you're booted in safe mode, bring up the task manager (ctrl+alt+del)
select file->new task (run) and type in
msconfig
check normal mode and OK. restart the PC
I have attached the config screen from my system for you to see(i did not do this in safe mode)
attachment.php
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    Realtek 7.1 CH HD Audio
    1280x1024 + 1360x768
    150GB Raptor HDD
    500GB Caviar HDD
    Thermaltake W0133RB 1200W PSU
    Antec 900
    Stock + Antec 900 case fans
    Logitech G15 (full layout)
    Logitech MX Revolution
Thanks ripbox, your suggestion worked! I did have to go to one other tab and check another box but other then that your instructions worked.
