Go Back   Vista Forums > Vista Forums > System Security
Vista - Shutdown Shortcut behavior when executed
Old 09-06-2008   #11 (permalink)
XP-Pro-SP3-32bit, Vista Ultimate-64bit
Re: Shutdown Shortcut behavior when executed
I'm not sure.....but, that looks like a message from UAC......
My only question is "Why is that P.O.C. even running on your PC?"
It's almost the very first thing I disable when working on a Vista PC.
Because, it interferes with everything else I have to do.
What happens if you tell it to allow that shortcut to run?
Shadow
Old 09-06-2008   #12 (permalink)
Vista Home Premium 32bit
Thanks for the reply...
I've disabled UAC and had it active (with the same behavior). After replying afirmative to the file security message the shortcut/cmd executes.
Tony
Old 09-06-2008   #13 (permalink)
WELL, is it UAC or something else that's giving you the error message.
I don't really recognize it.
I don't use UAC or any program like Spybot's "Tea Timer" that's always interrupting me while I'm working my PC. I have NO patience for those things.
The shortcut works just fine, you've got some other program bugging you, that probably should be corrected or deleted.
I sincerely hope you're not running any of that Norton crap!
Old 09-07-2008   #14 (permalink)
I'm going to reinstall Vista with a fresh install on my Laptop (no I don't have Norton). Things are starting to go wrong so it's time to do a cleanup.
Thanks for the help - it's shortcuts that point to EXE files that have the trouble. I'm always doing things like testing beta browsers (IE8 and Chrome). The good is I've learned things about Vista security via your forum etc.
I'm using the laptop to watch movies (from Netflix, Amazon etc) on my HD TV so I'll cut my Laptop some slack in the future and limit the experimentation on it <g>.
Thanks again.
User executed "System Shutdown (1115)" General Discussion
shutdown shortcut Vista General
Shutdown Shortcut Vista General
Shutdown shortcut Tutorials
change default behavior at shutdown Vista General
